DC header/down pipe tip size?
    Guys, i forgot what the size of the tip in a DC header is...
    2.25?
    I need to match my cat + exhaust and can't remember what the size was.
    HONDAMENTALISM
    whatever it was, it fit with my stock cat piping perfectly. So as long as you're using a oem style cat then it will work.
      So if its stock like, then what is the point of getting a bigger exhaust?
      HONDAMENTALISM
        yea the collector is really the draw back of a quality header. The header design is probably more free flowing overall than a stock one. Some people like Jdm_inspired use a two piece header with a 3" collector
          i think it's a 2" collector.. forgive me if im wrong, but i think its the same size as the megan header and ebay noname header also..
            Thanks for using me as reference
            I actually have a 4 piece tri-y header. I also have a 2.5 inch collector. Your DC is more than likely a 2.25 collector. There are some 2.5 inch collectors floating around.
            Follow me on IG: @jdm_inspired
            93 'til infinity
              Great...!
              So it does make sense ordering a larger exhaust...
              Thanks guys!
              HONDAMENTALISM
                The F22 DC header's collector is no bigger than 2.0", if even that big. It's definitely not 2.25" or 2.5". I'm eventually going to have mine cut at the "2->1" junction and 2.5" pipe welded in with a universal cat. So that's an option to keep open if you want to maximize your flow
                My Member's Ride Thread
                  yeah its prob. exactly 2". Even my GReddy 421 header has a 2" collector for my H22. That SUCKS! soon when i swap for a 5spd i'm installing a Hotshot 4-1 equal length runner header that has a 3" collector but reduced to 2.5" for the highflow cat and to match my exhaust.
                  member's ride thread
                  91 Accord SE 176k
                    It's 2". So is their cat-back system. I know cause I have both pieces and I just ordered a Flowmaster HushpowerII to install in place of my bad high-flow cat. I measured twice, ordered once.
