If you're removing the hub, then you don't need the adapter kit for the Honda. The adapter kit basically has a receiving tube that has a window / flat spot cut in it to clear the hub area of the knuckle.
I've done enough ghetto engineering in my life to know that is NOT the way to do any job, unless you are stuck on the side of the road, and really need to just get it together enough to get back home.
If I'm doing a job, I do it right. If that means that the half hour long job is going to take me three extra days because i need to order a part, or deal with something unexpected, well then it takes me three extra days. If I need a special tool, I either buy it, or get a loaner from the parts store, and if I can't do that, then I take it to someone with the tools / knowledge to do the job the right way.
I take a lot of pride in the work I do on my car, and I know that if I've done the work, it IS done right, something I often don't know when a mechanic has done the work.
