am thinking of doing a step down from obd2 p0a ecu and do a step down to a p28 obd1 what i want to know is that once i do the step down would the car still show up as a obd2 like if you go for inspection and when u plug up the check engine code hand set do i have to use the obd1 are the obd2 check engine code hand set
ecu step down?
Originally posted by rexload View Postno, you will have to put the obd2 ECU in the car to pass inspection,
i believe there is no other way around it unless you know somebody with the same car model as yours and still i dont know if the inpection place would be willing to take the risk in passing it like that
2014 bisimoto parts coming soon
Originally posted by rexload View Postwell you just take out the obd2>obd1 conversion harness, put your obd2 ecu back in and return everything else to stock.
this can be a big pain in the ass depending on the type of mods you have.
