My 92 cb7 has an h22a swap...it had ac before i bought it, but the guy had removed it when he put in the h23 that was in the car when i bought it (then I later swapped in an h22)...I was wondering if all the ac componets I have on my 1990 cb7 parts car would bolt right back in with no fittment issues?
A/C question.
I redid my a/c two years ago. If you have the old compressor fine, if not go a junkyard and get a compressor from a 94-97, they were 134 already. You will have to change the pulley, the 94 up have 6 rib and ours have 5, and you may have to change the in/out manifold on the compressor.
I did this two years ago and I get vent temps down to 40, in the AL heat. Everything else is stock.
good luck
