Things to know about changing the PS Axle
    Is there any DIY on how to change it?
    buy a haynes manual man...BEST thing! It's better than a diy on here cause you can take it with you.
    But you have to ubolt the axle bolt and usually that involves un-denting the the inner part of the bolt. CAREFULLY using a small but square chizel...
    Then I think (it's been a while since I did mine) you have to also have to get the lower control arm to hang so you can lift the knuckle up to get the axle out of it.
    Then get a tool from autozone that is made for removing axles...makes it easier. Or get a REALLY long pry bar, place one end on the axle by the tranny...lightly whack it...should come out. Sometime they are a bitch.
    DO NOT SHOVE THE NEW ONE IN...gently...carefully slide it in...and gently nudge it in...nothing suck like dinging the keeper at the end of the axle on install.
    On one side you'll have to undbolt the axle support.
    Buy new axle seals...easy to do, buy some GOOD tranny oil, go ahead and d&f the tranny. If you don't drain it a little then you'll most likely end up with the oil coming out once the axle is pulled out.
    If you don't have a lift...this is a major bitch...
    ____
      If this works for you then hooray.
      I had to remove the whole assembly from the lower control arm, put both ends of the axle in as far as i could, and use the hub to slam the axle into place. It wouldn't go in otherwise.
      Also, put just a dab of grease on the o-ring at the tranny end to keep it centered also. it helps make it easier.
        Yes using the knuckle with the axle in is the best way to get er in...I meant initial insertion...I know guys who line it up...then just slam it in and 7/10 times they doink the keeper at the end of the axle. You just gently tap it in, it'll stop...then use the knuckle basher to get it in.
        It really shouldn't take a ton of pounding to get 'er done.
        ____
          seems like a lot more work than i though :-\...i guess ill jus take it to a mech.
            You may just want to do that.
            To change an axle you have to remove the bottom balljoint from the lower control arm. (which is a bitch, even with the right tools.) and the lower shock mount. Also it helps if you disconnect the anti roll bar from lower arm too.
            It takes 2 people to do it. I just did my passenger side yesterday.
            When I took my old axle out, all I had to use was a pry bar and a little pulling. To get the new one in, I just put it in the hole and turned it while pushing until it slipped in. Some white grease on the ends of the axle helped them slip into place.
            Good luck with whatever you decide to do.
              What?? It shouldn't take two people...this is really not a hard task...well if you have a lift. But even without one...y'all are making this way harder than it is. But if you're squeamish about this then I wouldn't try it.
              ____
                See i did it with jack stands, and I had to have a friend pull up on the hub while I held the lower arm down. Same went for taking the old axle out.
                It might be possible by yourself. But its a lot easier for 2 people.
                  I highly beg to differ that its brutally hard to remove the ball joint from the arm. I learned this trick from a local member.
                  http://www.youtube.com/watch?v=ISY8bGof3bQ
                  He is doing this on a civic, i did this on my accord, and havent had any issues since.
                  I used a 22MM wrench instead of the 16 he put in.
                  90 Accord EX F22a1 Auto R.I.P.
                  2011 Mazda 3 Hatch 2.5L GS sport HELLO!
                    I did try this on my girls civic when I changed her axle, and it was easy! I didn't even have to kick the ratchet, I just lowered the jack and it popped! That freaking easy.
                    1992 Accord Wagon (RETIRED)
                      All you have to do is put a jack underneith the rotor once you have the lower ball joint nut off and smack the hell out of the lower control arm with a hammer and it pops right off.
                      member ride thread
                      DIVULGE MOTORSPORTS
                        Same here, the weight of the knuckle was plenty to pop mine loose.
                          like I said...it shouldn't take two people, and it isn't that hard.
                          BUT...if you think it is...let someone else do it.
                          ____
