question on rotors
    i was thinking heat would do the trick
      Originally posted by justin'saccord View Post
      i want to get drilled or slotted rotors for my 90 accord
      Unless you specifically want this for the bling value then IMO don't bother.
      Slotted rotors may be of some use for competition cars where the brakes can get very hot and 'gas-up', but make no difference to a road car unless the brakes are very inadequate ('gas-up' being when when severely overheated pads give off gas that prevents them remaining in contact with the rotor, but modern compound good quality racing and high performance road pads gas-up very little if at all). Holey rotors are almost never of any real value, even for racing cars...
      Best bet for a road car is good quality high performance pads and good quality blank rotors, keeping in mind that one of the things that slots do is to increase pad wear...
      Regards from Oz,
      John.
        So in your opinion what are some good name brand high quality racing pads?
          i will assume you are going to race on the track and etc.
          I would get Hawk pads there is a racing line.....or EBC red stuff(more for track) or Green stuff(more for track/street) if that is not enough for you get EBC Yellow stuff
          http://www.buybrakes.com/ebc/
          If you are not going to race. Don't waste you money on drilled rotor or Racing pad.
            Alright thanks man...
              the rotors with the large funny shaped hole in the center have to be pressed on and off of the hub. Its not a really bit deal. you just pull the spindles and take them to a machine shop.
              click to see my ride
              click to check out my bb6 dash swap
                I dont understand anymore... I keep gettin differ. opinions but do you know why they would have to get pressed on?
                  just ignore moetan.
                  The ROTOR IS NOT PRESS TO ANYTHING!!!!
                  get a hynes manual it will explain it all.
                    Lol ok then... Thanks
                      my 92 had to be pressed off. Mine may be different then yours but do what you think needs to be done.
                        on some accords the bolts might just take them off but on alot of older accords they are stuck pretty good. thats where the machine shop comes in. you may be able to just un-bolt them and take them off.
                          O ok i understand where your comin from now!!! It's difficult when you don't know and get differ. opinions but i'll see wat happens and wat works for me!!!
                            mine wouldn't just come off and I got tired of messing with them so instead of messing something else up I took them to the machine shop with the new ones and they hooked me up. It just made my life easier. I hope I helped
                              the rotor are NOT pressed on, i have 92 accord, i did the whole front brake, u just have to lose those 4 bolts with 10mm, and use wd40 to get the hub out, take times but NOT pressed on
                              this will help alot
                              http://www.honda-tech.com/showthread.php?t=1281812
