gears are grinding
    gears are grinding
    what causes the gears to grind and how to fix that
    have u tried transmission flush? maybe need some new honda trans. fluid.
      could be a lot of things. from adjusting the cable to synchros going bad.
      Project M3 - http://www.cb7tuner.com/vbb/showthread.php?t=157903
      -(B-Pillar Bar Originator)-
        yea my car onli does tht wen i give it gas while im switching gears i have a 5 speed
          It could be caused by not pushing the clutch...you'd fix it by pushing the clutch...j/k. Leak in the hydraulic system is another possibility.
            try bleeding out the clutch line, the problem might be linked the hydraulic system as was stated with the above post. and does it only grind on one gear like from 2-3 or it happens in all the gears
              low fluid ill do that . flushing it ill help
              CB-K for the win !!!!
                Do not flush the transmission. But change the fluid with Honda MTF.
                Chances are, your synchros are going. That requires a full teardown of the transmission to fix. Reaplacing the transmission is a better option. Cheaper, anyway.
                  it grinds from 1st to 2nd but only wen im hitting high RPM
                    Change the fluid. If it doesn't fix it, replace it. Or deal with it.
                      ya thats what i think it is
                        Are you going to keep repeating yourself until you get to 30 posts?
                          woww my car diffently does the samething! i know my clutch master cylinder is leaking so ima replace tht i have a new one from honda ima b replacing it this weekend so i'll let you know if it stops.
                          2004 Accord Sedan CM6 (daily)
                          Koni Yellows, Hood Bra,Splash Guards,Deck Lid,Weather Mats,Sunroof Visor,Fog Lights <-All OEM, Mugen Door Visors, 07 Tsx Wheels.
                          1990 Accord Coupe CB7 (project)
                          H22 Swap, Skunk2 Springs on Koni Str.t, Rear Disk Swap, Fog Lights, 92-93 Trunk Conversion, 02 Accord Rims
                            Most likely your syncros are going bad. Just gotta deal with it, shift more smoothly, or get a new trans.
                            Click for my ride thread.
                              O alright thanks bro...
