i recentlly found out that two if my injectors are f%*ked up so i want to buy new ones...any suggestions on good injector performance brands....price is not a problem
need new injectors
Originally posted by jdmtyteaccord View Posti recentlly found out that two if my injectors are f%*ked up so i want to buy new ones...any suggestions on good injector performance brands....price is not a problem
you wont need higher flowing injectors until you are making substantial power.
Originally posted by dano28 View PostJust how did you find this out ??
And yeah, you don't need any performance injectors. Just get stock replacement injectors.
Originally posted by jdmtyteaccord View Postmy car was acting up so i took a trip to a diagnostic place and they told me about the problem.....how much do oem injectors go for???
Yeah, buying brand new injectors would be pricey. As I said, injectors aren't common things to fail... so junkyard injectors are very likely going to be alright. And while I don't condone stealing... yeah, they ARE pocket sized... or sock sized.
Do you know how they tested for bad injectors? I'm still not totally sure that they are your problem... One failing is uncomon. Two failing is highly unlikely. If they ARE bad, then there's something contributing to that failure, and you'd be wise to find that problem before spending any money on new injectors that may fall to the same fate.
Get some junkyard injectors. Free if you don't mind stealing, and taking the risk of getting caught... or whatever their price would be (not too expensive, I'm sure). I'd snag all 4, just to have a matched set. Plus, if 2 of yours ARE bad, the other two may be right behind.
Toss the junkyard injectors in and see if there's a difference. I assume you have some acceleration problem, and aren't just going on the word of the shop without any apparent symptoms...
Originally posted by jdmtyteaccord View Postey ey...i might be a newcomer here but im not a newbie when it comes to mechanics.....i have lost acceleration power since i first bought the car and it has some starting problems...
you can always get junkyard injectors and have them flow tested, and I believe reconditioned?Last edited by ikayto; 06-06-2009, 03:01 AM.
