h22 temp rises up after a 1 to 2 hour drive??
    Hey guys, So I have a 93 Accord with a stock h22a automatic with no lsd. And I've been having this problem for a while now, but I've already excluded out 2 of my problems. 1) my radiator is leaking so I know that could be a factor 2) I've changed my OEM thermostat that I bought from the dealer just about less than a year ago. What else could be the problem? My dad and I advanced TDC to 16 and it actually ran a lot better. Oil levels, tranny level, all normal. I've searched all throughout the threads and couldn't find an answer similar to my problem so that is why I'm giving it a shot. I apologize in advance if anyone happens to find a thread that has the answer. Thanks guys.
    new $10 purple/yellow tint fog lights
    H22a Sleeper:
    http://www.cb7tuner.com/vbb/showthread.php?t=124470
    Well, start with replacing the radiator. If you know it leaks, why not eliminate that first?
      Well I'm trying to find out all possible problems. So I can fix it all at once, its not a big leak either. Like in the early morning or on a cold weather you can see leaked out, burning coolant arise out of the front end. But yeah I'll see if it eliminates it.
      H22a Sleeper:
        I just had to fix my T stat b/c it was leaking as well. I would fix the leak though. And then move on from there
          how can the cooling system pressurize when it has a leak?
            i had this same problem when i did the swap, i had those 2 sensors plug in backward and it overheat the engine, u have to unwrap the type to extend the wire for the plug, i m talking about the green plugs, ok
