low idle problem
    low idle problem
    92 h22a accord, my idle is normal when at stop, but when i turn the sterring wheel and brake, my idle will drop to like 300 rpm, can some1 help me out,
    i did this swap 5 years ago, i combined f22 and h22a distributor together, cos i didn't know how to do internat to externat back then , will that b the problem?? and i m running with NO cat.
    distributor parts combined
    h22a distributor frame , igniter, and the center shaft
    f22 wiring plugs, rotor, cap
    i already cleaned those parts
    iac, fitv, egr solenoid and set ignition timming.
    check vac lines, especially to the brake booster. test/replace the inline check valve to the booster & make sure it's in the correct way.
    edit - I own a MX-3, they are notorious for rpms dropping & lights dimming because you push the brake. lol this is the common answer for them
    Officially "hilarious mad sarcastic"! Thanks CB74christ for the recognition of my work.
      Cool I guess I know what to look into now. Been lookin for solutions to this for a while...
        is there any easy way to check vac leak beside just looking at the hoses? not just brake and turning wheel will drop my rpm, especially with the lights on and the a/c kick in, it made it worst.
          If you have one of the small propane tanks with a nozzel on it (like used for plumbing), you can just crack the valve so that propane is coming out and then move it through your engine bay, going over all the hoses, with the engine at idle. If you hear the engine pick up any, it is from the propane, which means you have a vacuum leak.
          1992 Prelude S w/swapped H22A
            check your air boost valve. it's suposed to keep your idle steady when stuff is turned on like A/C.
              http://bkhondaparts.com/billkay/jsp/...itch=&hidIrno=
              ok i found there a few of the vac hoses to tb is cracked, so i replaced them, but it didn't fix the problem, where is the air boost valve and how to check it? is it #7 at that pic? my rpm is fine it stays at 800 when stop, but i noticed that when i turn the steering wheel when the car at full stop, it wil drop the rpm, also when i closed the power window all the way up, it also drop the rpm, then when i let go the window switch it will go back to 800, i dont get it. the battery is new and the alternator is fine.
                Sounds like normal to me. Everyone's RPM drops when they turn the wheel (the power steering pump is a hydraulic pump, and making it work loads the engine). Same thing with the windows, you are drawing electricity, which loads the alternator, which loads the engine.
                How far does it drop? 100-200 RPM isn't a big deal.
                  it drop down to 300 then it will go back to 800, i'll guess this reply solved my problem, i thought only my car does that, but thanks for that reply
                    r u serious???
                    was it just the power steering??
                    has it always done this, or did it just recently start doin it???
                      its been like that after i did the swap
