Make me engine smart or accord smart
    Title says it all lol
    Ever since joining this site ive learned quite alot from not knowing nothing at all.. although i kno quite some stuff i still wanna kno more..
    Im thinkin of goin turbo by the beginning of nex year or so.. now my engine is completly bone stock but will have some mods by the end of the summer. now what are some things i will definitaly need to prepare for turbo cause i kno that if your engine is weak turbo can definitaly blow the engine out.. need i mention im currently at 170,000 on my cb7.. make me smarter guys.. teach me mr. miyagi (deevergote) lol
    Read more man. All the info is here, you just gotta find it. I figured out what I wanted to do by studying similar builds to what I wanted to do.
    1992 Accord Wagon (RETIRED)
      the only way ur gonna learn is to read and try things. good luck.
      The Hatch < < - - - - - - - - - - - - - - My Cars - - - - - - - - - - - - - - - > > The Accord
        Do a compression test on your motor to see if it's healthy. And make sure you have no oil leaks. Either make your motor healthy, or replace it with a healthy one... You're absolutely right that if the motor is sick, the turbo will kill it quick.
        Once your engine is healthy, then you need to research turbo setups. Search through the Members Rides area and find members with setups similar to what you have planned.
        You will NEED larger injectors, a properly sized turbo (Big 16G or t3/t4 would be the right way to go... no 14b or t25 garbage... a larger t3 would possibly be alright)
        Most importantly, TUNE! Your ECU has to be properly tuned for your specific application, or you're going to have problems. Don't listen to anyone that tells you that you can drive on a basemap, or that "my friend's friend's cousin had this chip in his girlfriend's car and it ran great for 20 years!"... Have YOUR ECU tuned for YOUR setup... or don't even bother.
        Get to reading, son. You have a year to learn a lot of stuff!
          cant stress enough, tuning is key.
          dont cut corners.
