Just wanted to know the what are the reasons for my cars hesitating problem, did the tune up rotor,cap,wires,spark plugs,oil change, oil filter, timing belt and so on and so on...... both of my timings are perfect, and stil when i drive around the block my h22a1 hesitates and bogs a lot, now im thinking it couldbe a fuel problem and i am putting 93 octane in it but i changed the filter like 3 or 4 months ago, i had this problem for quite sometime now and would really appriciate some help
H22a1 Help
im running the car on a crazy tunning p28 i heard they dont look for knock sensorsOriginally posted by N9netwoAccord View Postis your knock sensor detecting knock and retarding the timing? that could cause itStuff 4 sale 2nd gen dsm turbo manifold, ebay type s blowoff valve, 93 ex pt6 ecu, f22a6 camshaft, f22a6 intake manifold, obd1 p13 ecu
No codes but my timing is good could it be a fuel problem?Originally posted by mayberry View PostAre you throwing any trouble codes from the ECU? I would check that first. If it bogs without throwing any codes it has to be timing related.Stuff 4 sale 2nd gen dsm turbo manifold, ebay type s blowoff valve, 93 ex pt6 ecu, f22a6 camshaft, f22a6 intake manifold, obd1 p13 ecu
Yea I also checked the egr valve and it was good, I checked vacum pressure and its also good I'm thinkin it could be the fuel Filter which ill have to get tomorrowStuff 4 sale 2nd gen dsm turbo manifold, ebay type s blowoff valve, 93 ex pt6 ecu, f22a6 camshaft, f22a6 intake manifold, obd1 p13 ecu
my knock sensor wire was groundin out coming through the fire wall.Last edited by johnnyblaze2g; 05-25-2009, 11:17 AM.
Yea but I'm running it on a p28 they don't look for knock sensors right?Originally posted by johnnyblaze2g View Postmy knock sensor wire was groundin out coming through the fire wall.Stuff 4 sale 2nd gen dsm turbo manifold, ebay type s blowoff valve, 93 ex pt6 ecu, f22a6 camshaft, f22a6 intake manifold, obd1 p13 ecu
If your running p28...look at your tune...Are you running a basemap..If you are that is part of your problem right there.
Originally posted by NAiL05 View PostIf your running p28...look at your tune...Are you running a basemap..If you are that is part of your problem right there.Stuff 4 sale 2nd gen dsm turbo manifold, ebay type s blowoff valve, 93 ex pt6 ecu, f22a6 camshaft, f22a6 intake manifold, obd1 p13 ecu
