rust in front rear qtr panel
Originally posted by JDMCB705 View PostDon't have a grinder...any idea where to get one? should I peel off the peeled paint? The area of the rust is pretty hard still n don't wanna mess it up I never dealt with rust beforewat?
Just make sure you get a nice rust preventing primer on it before you do any other paint.
EDIT: I type too slow.1992 Prelude S w/swapped H22A
That's an odd way for the rust to appear. Usually it's over the wheel arch. That's the only place you don't have it!
Replacement quarter panels can be gotten from tasauto.com, or ebay (not sure on the ebay quality though). They have to be welded on, but if it comes to a cut and weld situation, i'd recomend replacing the entire panel. I've had a cut and weld patch done twice to mine, and it's reappeared both times.
Originally posted by deevergote. View Posti'd recomend replacing the entire panel. I've had a cut and weld patch done twice to mine, and it's reappeared both times.wat?
Originally posted by C91BLX7 View PostYour going to want to get a wire wheel and remove all paint and minor rust. then take your angle grinder and get the metal smooth ( not all rusty and pitted). after that's done hit it with some etching primer, lay down some glaze to get it nice and smooth. Then get your paint situation figured out and you'll be good.
