suspension upgrade
    suspension upgrade
    hey guys im looking to drop my car bout 2.4". wat things should i get for this?? i know lowering spring. do i need 2 get camber kit special type of struts or anything else like that?? thanks in advance
    http://www.cb7tuner.com/vbb/showthread.php?t=138029 <-mrt
    diy whore riiittteeee here
    [URL="http://www.cb7tuner.com/vbb/showthread.php?p=2208455"]
    http://www.b20vtec.com/forums/members/pr3pg4lyfe.html
    I gots Sprints. They lower about 2.5". I also got shocks with an adjustable perch so the whip sits lower than that. If you gonna do all that prolly should upgrade shocks, there's so many different kinds I don't know where to start. I also gots the camber kit up front cuz I don't care for negative camber. The rear I just put in washers and it works fine for me. After all that got an alignment and rolled out.
      Most shocks aren't made to handle a 2.5" drop. I would recommend Koni Yellows (also known as Koni Sports). They have the adjustable perch for height adjustment. They have a lifetime warranty, regardless of how low the car is (others void the warranty after 1.5", which is barely noticable as a drop)
      As for a camber kit, DEFINITELY get one. People will follow this post with "don't worry about camber, it's your toe that you need to worry about..." but those peopel are morons, including my good friend Jake... If you plan on driving the car regularly, GET A CAMBER KIT! Once you have the camber kit in place, get an alignment IMMEDIATELY. This will correct your toe AND your camber. I suggest you go to Firestone, or another place that will give you a lifetime alignment package. I paid $200 at Firestone one time, and I never have to pay for an alignment again! Any time a wrench touches ANYTHING to do with your suspension, you should follow up with an alignment, or risk destroying your tires.
      I highly reccommend the adjustable upper control arms from www.TASauto.com. I have them on my car, and I would never have anything else. Nothing is safer or more effective (and I've had camber kits break on me... You DO NOT want that to happen!)
        thank for the input. i was acctually thinking about getting these springs TENZO 2.25" LOWERING SPRING SET from tas. sorry bout the opening its a 2.25 drop. id like the drop be between 2.25 and 2.5. so i would have to get camber kit and control arms. would it b better to get control arms for the front and back?? or dont really need the back?? and what type of perch you guys have?? and a while ago i was thinking adjustable coilovers would that need more stuff then the lowering spring stuff??
          The adjustable perches are part of the Konis.
          And yes, it would be wise to get the front and rear. I don't have the rear, and my rear tires are shot.
            koo thanks 4 the in put really apreciate it layter
              i got tein coil over kit and front camber on my 92 h22a accord, dont spend money on rear camber, just buy some washer to shim it out
                You know camber is the angle of your wheels, right?
                  if dats for me then yes ive taken beginners mechanics i got a sheet around here with all that camber caster and toe and im pretty sure im missing like 2 bu ill find da paper
