is this a direct bolt on replacement? the reason i ask is a have an a6 head laying around and my a4 head needs valve seals...so i thought just put the a6 head on....anyone done this?????
A6 head on A4
it would be easier and less work to just do the cam and intake manifold. cheaper all around as well.
member ride thread
DIVULGE MOTORSPORTS
You don't have to mill the head if it's straight. Milling is only necessary when the head is warped.
Take it to an automotive machine shop. If you can't find any, go to a local performance shop and they'll tell you where to go. The machine shop can test the head for you, and mill it if they have to. Milling will bump up compression a bit, which is good. but it can also have some harmful effects. Plus, once a head is milled to a certain point, it's done. If you blow a head gasket, you'll need a new head.
You don't want to "mill" the head, you want to resurface the head. There is a difference. Typically you mill the head to raise the compression ratio, with a resurface, you are just making the head surface true, which often involves removing FAR less material than "milling" the head to raise the compression ratio.
Just trying to clarify on these terms, as they are often confused.Originally posted by sweet91accordif aredy time i need to put something in cb7tuner. you guy need to me a smart ass about and bust on my spelling,gramar and shit like that in so sorry.
Originally posted by foamypirate View PostYou don't want to "mill" the head, you want to resurface the head. There is a difference. Typically you mill the head to raise the compression ratio, with a resurface, you are just making the head surface true, which often involves removing FAR less material than "milling" the head to raise the compression ratio.
