Originally posted by deevergote.
View Post
back fire?
damnn a fire!?! thts no good! ima check the plugs 2mo im running low things to check..2004 Accord Sedan CM6 (daily)
Koni Yellows, Hood Bra,Splash Guards,Deck Lid,Weather Mats,Sunroof Visor,Fog Lights <-All OEM, Mugen Door Visors, 07 Tsx Wheels.
1990 Accord Coupe CB7 (project)
H22 Swap, Skunk2 Springs on Koni Str.t, Rear Disk Swap, Fog Lights, 92-93 Trunk Conversion, 02 Accord Rims
Originally posted by justin'saccord View Postmy car does the same thing when im down shifting it pops all crazy sounds pretty cool if you ask me . and wen i take off from 1st to 2nd at high rpms thats when mine back fires i got headers and a full catback exhaust i thought it was just air flow
my h22 used to do this. the p13 ECU for the h22 runs a little rich from the factory. i also had a header into straight pipe to a skunk2 catback... i had a straight pipe welded in place of the cat.
in cold starts if i take off somewhat decent and let off to shift into second i will shoot a small flame. i have a chipped ECU now. when i had the p13 i could shoot flames basically everytimg i shifted into second and third
Originally posted by N9netwoAccord View Postmy h22 used to do this. the p13 ECU for the h22 runs a little rich from the factory. i also had a header into straight pipe to a skunk2 catback... i had a straight pipe welded in place of the cat.
