tranny swap
    tranny swap
    hey guys i searched the forums but nothing came up. anyway i have a 90lx 4 door with an automatic transmission. i found a 92 accord ex 2 door 5 speed manual. i was wondering if i could swap transmissions out of the EX and into my LX. I have the whole car so parts wont be an issue.
    thanks in advance Ean
    Yes everything will swap over. The ex tranny has a couple shorter gears in it so it would be a little better in that sense. But you'll need the esp auto to 5 speed mount or cut the tranny bracket out of that car and weld it into yours.
    -1991 Honda Accord LX H22a-
      what mount should i cut out and weld. Also can i put the head of the ex onto my lx. the ex is an external coil and my Lx is not. Jist change distributors right.
        I would recomend buying the esp auto to 5 speed mount.
        The 5 speed transmission bracket that is spot welded to the engine bay would have to have every spot weld drilled out to remove it. Then remove the auto bracket in your car the same way. To get it in the right spot i would put the tranny on and bolt it up to mock the 5 speed bracket up with the transmission mount on and everything. Then weld it to the engine bay. But don't forget to get the paint off.
        The head will go right on and your right about the dizzy.
          swapping heads does not net enough power to be worth the work. if anything just swap the A6 cam in.
          as far as the tranny swap there are quite a few write ups on how to do it and what you will need may just need to refine your search a bit.
          member ride thread
          DIVULGE MOTORSPORTS
            im only switching the heads because mine ticks and the exs head was just rebuilt 1500 miles before i bought that car. but thanks for the help guys
