Help Need to Know about Engines plz plz
    Got another CB7This time its stick .
    my question is that what engine is good , like i prefer something to pull a lot of horespower. Like everyone knoes about the h22, but isnt there anything better then that, cause for sure im going to drop a turbo and more add on . I heard about the EURO R engine but i dont knoee what it called like is it a F engine or H engine, and i want to knoee about the f20b if u can explain all if you could :P thank you ,can you guy help, pick what engine will murder the streets. Im in highschool im getting kinda mad lookin at diz kid with Del sol in the student parking lot showin off. i wanna show what CB7 can doo, thanks plzz help
    build up your f.
    I am the "other" white meat.
      but iznt dis F slower, the only thing you can do is probley turbo and ECU tunning right, how that gona pull lot of horses
        check bisimoto.com for all of you answers.
          Thanks, but styll kinda confusing
            if you want a lot of horsepower, you'll need a turbo setup for sure.
            you can build your F22 and boost it, it will be around 400-500horses with about $3K in parts. just make sure you know exactly what you are doing before you start buying parts or it will end up costing a lot more. good luck
              euro R is a red top jdm h22a. if ur gonna def boost, do it to ur f. the euro r motor is prob gonna run u 2500 to 4000 for a swap and buildin ur f and boostin it may not cost more and yeild more poetint. speed has a pricetag, how fast do u wanna go?
              the rebuild!
              http://www.cb7tuner.com/vbb/showthre...50#post2073450
                http://www.cb7tuner.com/vbb/showthread.php?t=48695
                As far as anything beyond that...Unless you go V6 or find a way to swap in an F20C(s2000 motor) those are pretty much all your options.
                Look up LoDollar. He's got a massive build up.
                And theres someone else who did a k24 swap...His name is scott. 2.2--something or...i forget.
                Boost is always cool.
                Originally posted by Jarrett
                  First, try not to use that crappy e-speak. It tends to piss off the people who's help you want. If we have to translate what you type, we'll just move on because the info is there if you look.
                  Second, look through the swap section, the member's rides sections and the beginner stickies (Those are the threads at the beginning of the forum, they contain most of the valuable information you'll need.)
                  Third, as stated: Check out bisimoto, google him, youtube him, however you look. He's running an NA f22a putting down over 450 whp, IIRC. He also sells a turn key motor in three stages, if you've got the money.
                    A properly built F22A will make as much power with turbo as any other engine... The F22A has as much potential, if not more, than any other reasonable swap for the CB7.
                    There are 300hp NA F22As running around out there. And 500+hp turbo F22As.
                      Well the Euro R is just an H22, has different cams and a few other thing done to it. The F20B is just a destroked H22 Type S(or Euro R, I'm not sure if there is a difference other than where they were produced, the power is the same). For what it sounds like the H22 swap would be your best bet, considering you don't have the knowledge or prob skill it would take to build the F, the H would be more cost effective in your case. Also if you have any ideas of showing off, don't its retarded. You'll prob end up getting caught for street racing and boom, bye bye CB7 that you put a good amount of money in. I don't see why your upset because of a Delso, come on now, seriously? Let the Civic and Delso owners do as they please. On a side note where the hell did you learn grammer, I'm in high school and my grammer is far superior to yours. As for making more power, we need to know more. Do you want to boost it? Stay N/a(naturaly aspirated)? BUDGET!!!? Mainly budget, horsepower costs, if it didn't everyone could be driving around in 400 horse street monsters.
                      "The Turtle"
                      DD/Trail Rig/Mud Bug
                        do you have the f22a1,a4,or a6? you can makit quiker by putin a h22 trany, mod the intake, new cam, pistons, dsm turbo setup.
                        but if you want something to bolt right in the go h22a from the forth gen lude, i bet you can find one for cheap at the junkyard
                        back at it again
                          Just make sure to get the OBDI not OBDII you'll have to do a little extra to get the OBDII H22 to work.
                          "The Turtle"
