Well, I looked at 99% of the threads here about the mystery the cigarette lighter problem. IF any one has a cigarette lighter that they depend on like cell phone charger, accessory power supply (interior lights/underground lights...etc), electric tire pump (bycicle pump) or just simply used to light a cig and they go to plug it up and nothing happens, its a very inconvenient! well, if you look under your hood into the fuse box located on the passanger side firewall, you should see a label on top that says "[interior light]", that fuse should be BLOWN. If it is, change it out obviosly (and dont put a higher amp fuse cause that could burn up your wires going to the outlet and would cause a bigger problem) and it should work again...if it isn't blown, and your cig lighter still doesn't work...I'm sorry buddy..try again lol.
Hope this helps out...if not, I hate waste another thread lol
