Changing the Engine Mounts
    the engine mount to the left side of the engine...is it only jus 3 screws that need to be taken out?
    cause i no theres one long screw that goes through the engine mounts then i believe then 2 more screws that connect the engine mount to the chassis? Correct?
    Do you mean the transmission mount?
      if u open ur hood, its the one on the right hand side when ur facing the car
        Ok. Just making sure. "right" and "left" sides tend to vary from person to person... some say from the driver's perspective, some from the underhood perspective!
          ok, so back to my question though
            yep, very easy. just support the engine with a jack with a block of wood on it
              yeah, they take a 17mm socket, I had to use a deep socket since the bolts are so long. One is a nut, the other is a bolt. Then there's one 17mm bolt that goes through and secures it, so 3 things in all to remove that mount. VERY simple. Just make sure you support the engine, because it will drop down once you loosen that nut/bolt
