i was wondering if any one can tell me what horsepower gains i will get by adding cold air intake,heade and exhaust to my 92 dx f22a1 thank you
help me
well the intake wont really do anything for hp just add a little throttle response if any hp comes out of it id say less then 5 and the exaust well be about 5 to 6 hp and header most company claim to add about 12 to 15 so in the end youll add about 10 to 20 more hp with these add ons but you never know you could end up with more then that.
Originally posted by 92accordcb7ex View Postwell the intake wont really do anything for hp just add a little throttle response if any hp comes out of it id say less then 5 and the exaust well be about 5 to 6 hp and header most company claim to add about 12 to 15 so in the end youll add about 10 to 20 more hp with these add ons but you never know you could end up with more then that.
Originally posted by jasraq8387 View Postis there any kind of aftermarket or bigger intake manifold to put on or swap with.Last edited by visualpoet; 05-12-2009, 06:15 PM.
Originally posted by N9netwoAccord View Postyou will not see anywhere near gains of 15-20 hp from bolt ons with our motors... maybe 5-7, and thats being generous.
K series will get you 20 hp from bolt ons. sorry to burst your bubble
With me, 1/2 tank of gas and my stereo equipment in the car, she weighs in at about 3150 lbs and I can get her through the 1/4 at 15.87 @ 88.4 mph. The math says that means 155 whp by ET and 169 whp by trap speed.
15 or 20 hp from bolt ons is very realistic. Even if he only got say 3-5 from each item, IHE would put him at 9-15 hp, however, each one works with the other ones to give more power. Say the intake gives him 5 (just a number) by itself, and the exhaust gives him 5 by itself. Because they each make the other one work a little better (more air in and out than each by itself gives) there is an slight exponential increase in power, so instead of just 5+5 = 10, you can see an additional 2 or 3 hp. Like a bonus. You won't ever see the humbers like the ebay sellers would have you believe, but you can still get 15-20 from IHE.
Originally posted by visualpoet View PostI've shaved over 2 seconds off my 1/4 mile and am putting down about 160 whp. All I've done is IHE and a p12.
i agree with what you're saying, how one of them wont do that much with the other, but i still dont ever see one of our motors, gaining much from I/H/E
i'd personally like to see a dyno of before and after of the same motor stock and with I/H/E.
Originally posted by N9netwoAccord View Posti agree with what you're saying, how one of them wont do that much with the other, but i still dont ever see one of our motors, gaining much from I/H/E
If you want to make power for little money... hit up a junkyard, or www.car-part.com
Look for:
F22A4 header - $15 (90-91 Accord EX)
F22A6 camshaft - $25 (92-93 Accord EX)
F22A6 ECU - $25
H23A1 intake manifold and throttle body (from a Prelude SI, 92-96 I believe) - $45
F22A6 IAB "black box" (to be able to activate the secondary runners, the intake air bypass, in the H23 manifold) - no price listed... probably $10 or so.
The prices are from my local junkyard, which is average for most things.
Your stock F22A1 engine's horsepower rating is at 125. The F22A6 parts alone will bring you to 140. The A4 header should get you to 145 (the ONLY difference between the A1 and A4 is the tubular header on the A4... which is superior to both the A1 and A6, which both have cast manifolds) The H23 intake manifold and plenum should add another 5hp or more... no exact figures are set for that.
If you do the camshaft, which isn't a HUGE part, but it helps, you're going to want to replace all the gaskets and seals you come across... good preventative maintenance anyway! That'll be another few bucks... but not a whole lot.
Get a cheap short ram intake. Have a muffler shop slap a 2.25" system for you.
The stock Honda parts would run about $120. A cheap short ram can be had for $50 or less. Exhaust... depends where you go. I paid $450 for new piping, cat, and muffler. You can probably get away with keeping your stock cat. Find a cheapie muffler on ebay, maybe a used one. Pay for piping and labor only. $200 at most for everything, I'd say.
So... that's under $400, and you can gain a minimum of 30hp... that doesn't include the intake and exhaust gains.
These things have been said over and over again... but I figured I'd make a post stressing just how simple things were!
Originally posted by visualpoet View PostHave you not read the sticky about making 30 hp for less than $500?
Originally posted by visualpoet View Post15 hp between the a1 and a6, and that's just a difference in I/E manifolds, a small difference in the exhaust and a slightly wilder camshaft.
edit: thats what the OP was asking about... maybe thats why i'm so stuck on just those 3 items
