Oxygen sensor help
    Oxygen sensor help
    I'm probably gonna get bashed for asking this, but...
    does and obd1 civic/integra oxygen sensory fit our accords?
    I believe ours is a 4 wire o2, right?
    I'm throwing code 43, fuel system, i've heard of people getting this with a faulty o2...
    You are correct. Ours are 4 wire. A white, a green, and 2 black wires, I believe.
    And I'm not sure if the Civic or Integra sensors would work??
      the wireing might be diff. (length of it) and the plug could also be diff. depending on if you need a male or a female plug end.
        I can get a civic o2 sensor for free, if its to short, i can lenghten it.... just trying to save +$100
        if the harness is the problem in can cut the old harness from the original o2 sensor and solder it to the civic o2.... now the only hiccup would be if it'll thread into the bung in my exhaust piping...
          I got my denso o2 sensor for my accord for $45 and it came with the plug from Bap/Geon.
            is it still working lol.
              Bosch one from autozone is 70 bucks. exact fit. why hassle? If you can get it for free, get it, and try to put it in. might work.
                try injector and fuel system cleaner
                  i did a half a can of seafoam throught the intake vacuum and the other half in the half a tank of gas...
                  anyother brand cleaners you recommend? sounds like the cheapest easiest alternative right now.
                  and i'm getting random sputtering. usually when downshifting
                    The Bosch ones require soldering to work correctly. They don't work correctly out of the box.
                      Yes it is still working, denso is an oem manufacter for honda, if this one goes out, i'm replacing it with a ngk/ntk.
                        make sure your contacts on the 02 sensor and electrical path are clean, and being made! also reset your ecu and drive it for a tank with a cleaner. I used canadian tire shit but im sure youll have problems finding it down there im sure most brands are the same.
