Okay so today we finally lowered the engine into the CB but we ran into one problem. I thought I was supposed to buy a H23 motor mount because I have the h23 tranny now but it does not bolt up correctly. Can someone PLEASE help me out what motor mount am I supposed to use? I want to go to the junkyard/autozone tomorrow maybe and buy it
H22a Critical!!! Motor Mount!!
Originally posted by NJ_STAMPEDE_LX View PostOkay so today we finally lowered the engine into the CB but we ran into one problem. I thought I was supposed to buy a H23 motor mount because I have the h23 tranny now but it does not bolt up correctly. Can someone PLEASE help me out what motor mount am I supposed to use? I want to go to the junkyard/autozone tomorrow maybe and buy itOriginally posted by SWAP FAQTransmission Mounts:
For the 5-Speed you will to use a 10x1.25mm tap to tap the two unused holes in the Prelude transmissions case. Before you can do this the holes need to be enlarged with an 11/32" drill bit... get a drill bit that is made to drill through metal! Remove the two studs from their old location, and install them in the location you just drilled and tapped. Then you can mount up the Accord's tranny mount on the Prelude transmission.
For Autos nothing is needed it just bolts up with no additional modding.
Since you have the Prelude tranny, you have to do the drilling/tapping process.1992 Prelude S w/swapped H22A
