Would a P12 ecu work with a f23 motor?
question on a ecu?
However, you're using an OBD1 non-VTEC ECU designed for a 2.2L motor on a 2.3L OBD2 VTEC motor... LOTS of things are different. For one, you wouldn't have VTEC.[/QUOTE]
That makes me wonder, I have a f23motor and im runing my stock 92accord ecu on it. im runing my V-TEC to a switch
WHAT U KNOW ABOUT THAT?
Originally posted by f23accord View PostHowever, you're using an OBD1 non-VTEC ECU designed for a 2.2L motor on a 2.3L OBD2 VTEC motor... LOTS of things are different. For one, you wouldn't have VTEC.
That makes me wonder, I have a f23motor and im runing my stock 92accord ecu on it. im runing my V-TEC to a switch[/QUOTE]
damn i would get a poa or a tune soone because that isn't that good on the motor at all and every time you drive a mile you are probley putting 5 mile worth of wear on it
Originally posted by f23accord View Postthat would explain why my motor is acting up. Man thats sucks
Your motor should be making 150hp. An ECU from a 135hp engine won't do anything spectacular for you.
Get an OBD1 POA (94-95 Accord EX ECU... it runs the F22B1, which is much more similar to your F23A1). Or get a custom tuned P28... but have it tuned to YOUR engine. Generic "chips" are bullshit, and can do damage. Anyone who tells you otherwise is just trying to make a buck... or they're dumb as a brick. Either way, not to be trusted.
Or, convert the car to OBD2 and run the proper ECU for the F23A1.
It sounds to me that the guy who did the swap was a total retard. I'd spend some time learning about the CB7, the F23A1, and how it SHOULD be swapped in (we have a few members that have done it properly on here, I'm sure they'd be glad to help you). If this joker hooked VTEC up to a switch, who knows what other ghetto-rigging he's done! I mean seriously... that is GHETTO right there.
Now, you say he used the "same dizzy and intake manifold"... as in, F23A1 dizzy and manifold? Or F22A1 dizzy and manifold?
It costs no more to do it right. If you can't afford to do it right, you can't afford to do it at all. Now your expensive motor swap could potentially be damaged. That costs a little more to fix than simply running a proper ECU and doing a little wiring.
That's one reason why there are so many idiots in this world. People would rather make excuses and defend the stupid, rather than educate the ignorant and condemn the lazy.
Additionally, I've attempted to help you. Rather than answering my questions, which might actually save your motor, you chose to defend the moron. Have fun with your switch. I'm done here.
So, in hooking his VTEC up to a switch, could he be in VTEC all the time, as long as the switch is on?
And not to be a dick, but, if you can't do something right, don't do it. Point blank. And like Deev said, "ghetto rigging" something could cost more in the end than doing it correctly.
I feel sorry for your motor.
I wonder how long it'll be before we see a thread on something that went south on this swap?
Best of luck
Originally posted by deevergote. View PostIt costs no more to do it right. If you can't afford to do it right, you can't afford to do it at all. Now your expensive motor swap could potentially be damaged. That costs a little more to fix than simply running a proper ECU and doing a little wiring.
THATS REAL FUCKED UP BRO, WHEN I DIRENT EVENT SAY SHITE TO U deevergote, UNLESS U PUT THE LAST POST. I HAVENT DISRESPECTE U BRO. IT MAKES ALOT A CENS WHAT UR SAYING, AN U OVER CALLING ME AN IDIOT, ANOTHER THING IM NOT MAKING EXCUSES. I HAVE HAD THIS CAR WITH THIS SWAP FOR 3 YEARS ALREADY. 2nd I SAYED THAT THE V-TECK WAS HOOKED UP TO A SWITCH, I NEVER SAY I USE IT, IM NOT THAT STUPID, AN IT IS DISCONECTED. SUCK WHEN OTHER PEOPLE PUT DOWN OTHER PEOPLE ONLY CUZ THEY KNOW MORE ABOUT CARS THAN OTHERS, BUT ITS COOL
Originally posted by f23accord View PostTHATS REAL FUCKED UP BRO, WHEN I DIRENT EVENT SAY SHITE TO U deevergote, UNLESS U PUT THE LAST POST. I HAVENT DISRESPECTE U BRO. IT MAKES ALOT A CENS WHAT UR SAYING, AN U OVER CALLING ME AN IDIOT, ANOTHER THING IM NOT MAKING EXCUSES. I HAVE HAD THIS CAR WITH THIS SWAP FOR 3 YEARS ALREADY. 2nd I SAYED THAT THE V-TECK WAS HOOKED UP TO A SWITCH, I NEVER SAY I USE IT, IM NOT THAT STUPID, AN IT IS DISCONECTED. SUCK WHEN OTHER PEOPLE PUT DOWN OTHER PEOPLE ONLY CUZ THEY KNOW MORE ABOUT CARS THAN OTHERS, BUT ITS COOL
The p12 will do nothing for you. Get the correct ECU for your motor and you'll probably be amazed at the difference.
