Car started fine and now it doesn't start
    I started my accord today had been running all fine and dandy. I knew i had a misfire on one of my cyl and while the car was running my buddy thought it would be wise to pull on of my plug wires out (cyl 1) and my car died. I have been trying the rest of the day to start it and he said it may be the distro is fried now i get no spark at all. I need to figure what to do to get to the bottom of this problem.
    The CB7 Collector.
    92 LX Coupe F22A1
    2013 Toyota Corolla S
    92 EX Sedan F22A1
    Check the 2 connectors that go to the distributor and check plug wire condition and seating.
      Pulling the spark plug wires one at a time is how you can check each cylinder to see if it is firing so I doubt that had anything to do with why the car is not starting now.
      You say the car is getting no spark.
      Did you pull the dizzy cap? How does the points and the rotor look in there?
      Another thing is it could be a bad ignitor.
      Also, believe it or not the problem could be the main relay. That relay also controls electric to the coil.
      PARTING OUT MY 1990 EX COUPE!! EVERYTHING FOR SALE! CLICK HERE
      Listen or download the first 4 songs I completed for my new upcoming album here!!
      My member's ride
        Does it matter which dizzy i use to replace it? I have an H22A can I use any F series dizzy if can't find an H one?
        The CB7 Collector.
        92 LX Coupe F22A1
        92 EX Sedan F22A1
          Help please
          I have a honda accord ex 1991 manual and my car dont want to start i have changed the coil pack and after that i tried to start the car and no answer now i don't what to do so if someone can helps me that's appreciate thanks you at advances
