Steering wheel shakes when i press the brakes
    Ive posted a thread up before about my steering wheel shaking when im on the highway and slowing down from like 70 or 80mph...
    I changed my rotors and brake pads and the problem went away for like 2 or 3 months
    now im starting to get the same exact problem again when im slowing down on the highway
    what else could this be? i doubt its the rotors since ive already changed them not 2 long ago
    The rotors are warping again. Theres a lot of factors that go into this. Like the quality of the rotor, do you ride your brakes, what kind of pad is on them, and if you're calipers are operating like they should.
    Finally Up and Running. Numbers to Follow. Check my MR
      X2
      I would suspect the calipers are not functioning properly. Like they are having a slight drag which causes the rotors warp prematurely. Rotors warped on 2 to 3 months time is very unlikely unless you ride the brakes OR you just slapped in a crappy rotor.
      1996 Honda Civic LX 2009-2012
      2012 Kia Optima LX 2012-2013
        your rotors are more than likely warped like mine are. i just dont have the money to buy new ones yet. if you have replaced yours then take them to a tire or brake place and have them cut down to where they are ture and not warped.
        My cb7
        h22a
        5-spd lsd
        Lord, grant me the serenity
        to accept the things I cannot change,
        the courage to change the things I can,
        and the wisdom to hide the bodies
        of those people I had to kill because they pissed me off.
          Originally posted by Konigstiger View Post
          X2
          wut do u mean ride on brakes?
            Oreillys turns rotors for free
            LIONS GARAGE
            GARAGE*FRESH
              this is 99.9% warped rotors my moms car just had to get her front right rotor changed and it calmed it down alot but then they realized it was coming from the back not the front.
                next time you change, upgrade to better brakes rotors. It'll cost a bit more, but WELL worth not having to mess w/ them again until they're actually worn out instead of prematurely warped. The rotors are about an inch bigger (11.1" vs 10.2") and the pad is about 30% bigger than the stock CB7 pads, so that helps defeat brake warping
                Vigor Brake rotors
                Vigor Brake Calipers
                Vigor Pads
                Total cost was about 250. Which isn't a lot, considering how much mechanics charge to do brakes on our cars....just a suggestion.
                I've had my Vigor brake setup on my car for just over a year now and they're rock solid every time I hit the brakes, no shimmy or shaking and some of those stops are from 100+ mph.
                But another thing you have to have, which I just thought of is at least 15" wheels. So I guess if you don't have those on your car, then you might be kinda limited in your options.
                  It means holding your foot down slightly on the brakes while you're driving. This and late braking as you approach an intersection prematurely warps rotors and causes brake vibrations (which I explained before). I've seen it happen countless times in my tenure as a tech because people suck at braking. Brake early and brake light. It doesn't take much to warp rotors. 2 months is nothing. I've seen shitty drivers warp brand new rotors after a week of driving.
                  "The fault-finder will find faults even in paradise. Love your life, poor as it is. You may perhaps have some pleasant, thrilling, glorious hours, even in a poorhouse."-Henry David Thoreau
                    My 2¢
                    Just my 2 cents but along with warped rotors, tires out of balance will give you a shudder at certain tire revolutions, if say at 65 theres nothing but at 73 there is and you goto 82 and its fine again its the tire, so maybe while braking you have a bit of shudder, that could be it...
                    shitty OEM type replacement rotors do have the tendency to warp fast though. If you brake hard to a light, do you sit still? You should allow the car to move a bit to disperse the heat evenly, not brake hard then sit at the light, itll warp them quickly.
                    Also like the other person mentioned if your caliper is crusty and not working right, itll drag (the brake pads) and heat the rotor up way too much
                      cheap rotors will warp quickly as well...such is my situation...
                      ____
                        I do this, because I thought it would be better for my rotors if I lightly pressed on them instead of moderately while coming to a light.
                        Now i have shakes...they come and go.
                          If you have a habit of washing your car when the brake rotors are hot be careful not the spray cold water directly on the rotors. Remember that rotors are cast iron, not steel.
                            That sounds like the correct way of doing it. I was describing two different scenarios of improper braking. Riding the brakes while you're driving (typical move for tailgaters) warps the rotors. If you brake late as you approach an intersection (meaning you push down harder on the pedal to stop the car to compensate for poor timing), you'll eventually warp the rotors. When you approach an intersection, the way to put less strain on the brakes is to brake early and brake smoothly. You want to ease into the braking-start light, just like letting out the clutch; if you brake early, you usually won't have to put in that much pedal pressure anyway because the friction between the road and the tires will have more time to stop the car.
                            Even with generally proper braking, the rotors are PROBABLY still going to get warped. Using poor quality parts is a big factor, but sometimes you can't prevent incidents of excessively hard or frequent braking. Maybe an object unexpectedly enters the roadway or you have to drive behind some brake-happy douchebag in stop-and-go traffic. Shit happens.
                            Turn your rotors. That should take care of the intermittent shaking. I assume it happens during high-speed braking (>65 mph).
                              Turn your rotors. That should take care of the intermittent shaking. I assume it happens during high-speed braking (>65 mph).[/QUOTE]
                              yea, the shaking is worst at this speed
