main relay
    main relay
    ok is the main relay that everyone is telling me to change cause my car wont start at times the MAIN relay or the EFI MAIN relay....just wondering cause im gonna replace it in the next few days and i wanna get the right one
    thnx to everyone on here that has helped me out..let me know
    steve
    IM IN LOVE WITH A CAR..IS THAT WRONG?
    MY MR THREAD
    http://www.cb7tuner.com/vbb/showthread.php?t=132771
    steve
    That would be it.
      Originally posted by Grin0048 View Post
      That would be it.
      ok what would be it? the MAIN relay or the EFI MAIN relay...u didnt specify!!!!
      MY MR THREAD
        it should be the main relay under the dash on the driver side its gray and held in place by one bolt you have to remove a black box in front of the relay before you can remove the relay they are both held on by 10mm bolts two on the black box and one on the relay
          ok thnx i thought both relays were under the dash....thats what auto zont told me??????
          MY MR THREAD
            Oh, sorry, I just meant that they are the same thing.
              if they r the same thing then why are they named two different things and why do they cost different prices?????
              MY MR THREAD
                I wouldn't get too hung up on what autozone or the specific aftermarket manufacturer has decided to call it especially since neither is absolutely correct...it's actually called the PGMFI main relay. As for price...different manufacturer? I don't know, maybe I'm mistaken, but I don't think so.
                  ok thnx bro
                  MY MR THREAD
                    Are you sure that the main relay is your problem? When your car does not start and you have the key on the "on" position, can you hear that fuel pump making any noise? It's most likely the main relay but you should check if the fuel pump is making any sound just in case. Also, you can re-solider the cracked points inside the relay and save yourself some money. I know of people that have done this and it fixed their problem.
                    PARTING OUT MY 1990 EX COUPE!! EVERYTHING FOR SALE! CLICK HERE
                    Listen or download the first 4 songs I completed for my new upcoming album here!!
                    My member's ride
                      yeah i can hear my fuel pump when im under the car and someone is turning the key on....that was the first thing i checked...and then i read up on here and ppl said it was the main relay....so im gonna go with that for now i havnt had time to check it right now cause im tryin to get my jeep running but im gonna check it some time tomorrow..but thnx though man
                      MY MR THREAD
                        you getting any cel lights??? if not then its probably the main relay pretty easy to change akward position though
                        member ride thread >>> http://www.cb7tuner.com/vbb/showthre...73#post3257973
                          nope none...so im goin for it and checkin the relay
                          MY MR THREAD
                            Old post but I was wondering if fixing or replacing the relay fixed yur problem...?
