i got power to my coil an my fuelpump but not starting i check the mainrelay an its good ............
wont start
Is it low on gas?
Slamage is worth the Damage
Originally posted by crazymikey"Yes, we did officer. By the way, your eyes look a little glazed, did you just come from the donut shop?"
you really need to give more info... does the engine crank? voltage at the fuel pump is not a really good indication of fuel working or not. should check for injectors actuating or power at the injectors. just cause you have fuel there doesnt mean its squirting it. also the same with the coil just because you have power at the coil doesnt mean that the ignitor is making it fire. you should pull a wire out and put a plug in it and check for spark rather than power at the coil. Also have you checked to see if the cam is spinning with the crank< (broken t-belt.). There are tons of possibilities for a no start condition which is why when do you ask a question like this you need to be much more specific in what its doing, things like does it crank, engine codes, etc.
member ride thread
DIVULGE MOTORSPORTS
