So i swapped the H23 IM and TB on my a6 lower runners and i need help reconnecting them back. Which fitv do i use the f22 or h23 one. One one im using only have 1 nipple on it instead of 2. Do i have the right one. Its connected to the Tb on the underneath side. I need help with the running the coolant likes and figuring out which ones go in and exit on the valves. I know the outlets are on the water neck housing and the inlets are on the bottom side of the IM. The second part is on the vacuum lines for the black box and other nipples on the IM. Can someone guide me by which ones get hooked up and where. Thanks. Here are some pics I have to which Im working with. I have read the DIY on the swap but I was confused. I'm not sure if I have them hooked uo correctly soo far.
coolant and vacuum lines on IM swap
Coolant flow lines run like this:
Waterpipe To Throttle Body Nipple,
Out FITV Nipple under throttle body,
In Right Nipple of IACV
Out Left Nipple of IACV to Waterpipe
Make sure you hook the Air Boost Valve Vacuum Line to the top of your intake pipe and not the plenum itself.
All the vacuum nipples can be used for any vacuum operated system, so there is no right or wrong nipple to hook the vacuum lines up to.
As for the black box, if the car is an automatic its supposed to connect to the rear motor mount, the part that has a hose and the motor on the black box goes to the IAB Sylinoid. The wire for the black box goes to Connecter A Pin 17 on the ECU.
Note: You may have to find somewhere else to mount the black box because there is a power steering connector at least on my car that would conflict with the factory black box mounting location.
Good Luck!Last edited by cloudasc; 05-03-2009, 04:40 PM.
