4 wheel disks
    4 wheel disks
    I know this is possible but has anyone on this cbtuner tried it with a 9091 and how much is it? negatives? and on a scale of 1-10 how much more enjoyment do you get after the conversion and is it something a 16 year old would be able to do?
    It's doable if you have the tools... and the patience. TASauto.com sells a conversion kit, I believe... or you could get used parts from a junkyard. You'll need to use a 40/40 prop valve from an Integra.
    Check the DIY forum for details. At least one member has done a detailed writeup of the swap, if I recall correctly...
      got mines done a few weaks ago.found a 92 EX in the junkyard and did the swap to mine 90 LX.performance is great.not pricey at all.
