Morning all! Having a difficult time with a oil leak I behind the distributor. I know there is a O-Ring there and I have replaced it, but the stupid thing continues to leak a week or 2 later. It then cause issues with my wires on the tranny and around that area. Wondering if there is a better solution or part I need to use. Or if there is a magic trick I don't know. Any thoughts will be appreicated!
Oil Leakage!
there's only an O-ring in there. No cam seal.
Did you use a generic O-ring for the dizzy or did you get the proper one?
Just make sure you lube the o-ring before you install. If you put it together dry, it can try to roll out of it's groove and tear.
Either way, time to pull it back apart and take a closer look.
incorrect installation of distributor shaft o-ring. remove and replace the o-ring. lube and be more careful during install of the distributor to the head.Originally posted by Soichiro Honda, Honda Motor Company Ltd. FounderAction without philosophy is a lethal weapon; philosophy without action is worthless.
you CAN use a generic o-ring, but in order for it to work it must protrude slightly beyond the distributor shaft diameter when it is installed in it groove. This will allow it to crush slightly when you install it and create a positive seal.
oh, and definitely wipe a little oil on the o ring before you put it together.
(The O-ring you used may be close enough in diameter, but might be too thin.)
This exact thing is happening to me. It was leaking, i replaced the dizzy-O ring, seemed fine for a couple weeks and now my tranny is covered in oil again. Uses around a quart a month depending on how much i drive. Mabey i should get another one and LUBE it?
_____________________________________________
2 year ASE Certification/Auto Technician Degree completed
