Help!!!
    Help!!!
    So i get in the car after work n i go to press down the clutch to try n turn on the car...
    but apparently the clutch pedal is drained all the way to the ground without me even pressing on it...
    i go to check under the car and i see a leak coming from somewhere but i dont know where
    apparently my clutch pedal doesnt compressed back up to the top but it stays stuck at the bottom
    wut is going on. and where did the leak come from? i know the leak has to do with the clutch being all the way at the bottom
    bump!
      Fill it back up, and get someone to press the clutch while you check where it's leaking from.
        check your master and slave cylinder. chances are, the leak is around there.
          First...breath! HA HA..relax man nothing big...sounds EXACTLY like a slave cyl.
          Will take you no time to replace it...OR rebuild it for EVEN cheaper!!!
          ____
