Any updates on the car man?
Starting Problem (Main Relay?)
Another Update
Okay so my mechanic checked out the car today and this is what he did:
Check for fuel: Good
Check all fuses again: Good
Check For spark again: Fail
Check Timing belt: Good (thank god)
Changed coil: Done by me but not the problem. Dammit!!
After doing all that, he said that changing the Ignition Control Module might not even solve the problem. The reason for this is because he has a Civic in his shop right now with the same symptoms. The starter kicks but the car won't turnover. He changed the ICM and coil and got nothing.
However, another reason he tells me this is because both the Civic and my CB have alarms. I have only had mine for barely two months. It has remote start and a kill switch.
So tomorrow I am going to ask the guy that did the job if he hooked up the kill switch to the harness before it hits the dizzy, because I know he didn't hook it up to the fuel pump because I'm getting fuel.
Final Update it was the ICM
Well guys I am happy to say that my car is up and running again. It turned out to be the Ignition Control Module (Ignitor). I spent more money than I had to but it went to parts that will need replacing anyway so it's not really a problem.
The only downside is I will have to wait a little for my coilovers
Thanks to everyone that helped.
Where did you get your ICM from? My car has the same problems right now and I have checked everything you changed and checked.
Slamage is worth the Damage
Originally posted by crazymikey"Yes, we did officer. By the way, your eyes look a little glazed, did you just come from the donut shop?"
I'd have snagged an igniter from the junkyard before buying new... but buying new, although expensive, is always the better route for things that wear out.
My junkyard lets me take them for free... so whenever mine dies, I just grab another Coils are $5.
Glad to hear it's fixed! When you mentioned the alarm, that made me thing "oh boy... the problem is in someone else's crappy wiring job"... and THAT would be a pain to find and fix... Stock wiring problems are bad enough, but when they wires have been tampered with, who knows what could be wrong!
