The problem was fixed; It was the ICM.
Okay guys so last night I got home late around 3:00am with my car running normal as usual. However, four hours later when I was about to go to work my car did not start. The starter was kicking, but the engine wouldn't turnover after trying many times. So I spent some time searching and found some possibilities and methods of checking numerous things and this is what I have done so far: (I am trying to be as descriptive as I can)![5](http://www.cb7tuner.com/winkeye.gif)
Now those are the things that I have ruled out but these are the ones I am skeptical about:
Spark plug wires are not throwing a spark. I put a screwdriver in them and grounded them and got nothing, unless I did it wrong.![Confused](http://www.cb7tuner.com/confused.gif)
All my fuses are good except for one labeled 'starter signal', but after I replaced it with a good one, and tested it the car wouldn't start and the test light wouldn't light up on the fuse I replaced. The original fuse wasn't blown.
Also, I have remote start and a kill switch, but my friend said that both of those wouldn't matter because those cut power from the battery. If those were the source then my starter wouldn't even kick out.
So that's all I have so far. I read up on how the distributor, igniter, and the main relay under the dash can be the main source since they are common failures in accords.
Does this look like one of those failures?
- Oil level is normal
Opened oil filler cap and cams are rotating
Battery is healthy
Starter is kicking normal as if car were to start
In accessory mode fuel pump is turning on
![shrug](http://www.cb7tuner.com/shrug.gif)
