Does this VTEC engine fit our Vehicles?
    I think this is pretty cheap. It's interesting they don't mention mileage.
    http://cgi.ebay.com/ebaymotors/JDM-A...Q5fAccessories
    No link/picture.
      try it again
        Yes it will....its essentially a de-stroked h22......so it will bolt right in
        if it doesnt mention mileage or anything like that I woultnt take the chance.....if something seems too good to be true it generally is
        Burrito Bandidos: It will change your fuckin life
          Yes, it'll fit.
            It is possible, yes. Requires alot of wiring as its an OBD-II motor and were are OBD-I.
            See; AlmostJDM.
            Originally posted by Jarrett
              Alot of wiring sucks.. That's why I like our CB7.
                I've been reading info on VTEC engines, the swap guide and requirements etc... and want to start setting a goal for a swap in the future.
                  do it
                    This might be a noob question, but if the engine is OBD-II, and you got the tranny that came out of that car, also OBD-II and the ECU/TCU were both OBD-II....would wiring really be that hard? You essentially just be swapping everything to this car, parts AND wires.
                      cant u use the f22 harness anyways, just wire the vtec up, and i beleive you dont have to use the obd2 computer , isnt there a swap guide for this ?!
                      -1992 CB7 EX w/H22 [sold 10/09]
                      -2005 Legacy GT limited [current]
                        There is a swap guide but I believe they are not for this engine model. This engine is like for the next generation of Honda's. That's why I was wondering if it would work for our vehicles. I'm not buying it, I'm just gathering ideas/info.
                        Thanks!!!
                          Hey You watching the playoffs? GO CAVS !!!! James is annihilating everyone. I hope he keeps doing this.
                            yes you can thats what i did its only 1 wire to add unlike the h22 its 3 to 5
                            on obd2 engines the tcu is inside the ecu its all one main computer, and i think the hardest part about switching to obd2 is adding all the sensors, and the immobilizer
                            See; AlmostJDM.
                            no it doesnt even less then an h22 unless you use the f20b injectors then its just depinning the obd1 injector clips an dputting the obd2 ones on
                            PSN ID's:Tidashoni
                            1992 Accord EX Coupe
                            My FS Thread
                            Boosting with a carb is like being a sniper with a bazooka... it works, it gets the job done, but it's not the most precise method.
                              Thanks for the clarification. I figure if I'm gonna swap I do want a younger engine to keep the ride going for a long time after plunking down $1500+ on a 20+ year old car..
