Will this ECM work with my 1990 ex accord?
    This Computer is a P06 ECU chipped and converted to P75/P07/PR4/P05 specifications.
    I know the P06 will work, but I dont know what the 'converted to' part means. Thanks.
    1989 cressida: Polycog diesel ultracharged, high tension muffler bearings, Manestically spaced pivot bearings, High definition halogen fluid, Flourescently scored bio-fuel seperator, flux capacitor and a Sega Genesis hooked up to a 9" b/w tv via cable to antenna converter.
    a chipped p06 can be configured to other ecu specs.
    depending on your setup, this may or may not be your best option.
    Bought from: Bisimoto, FuncOvrForm, HondaGuy1212, wed3k, Konigstiger, 1st2run, BillKisme, k-mart, benjerman112
      Will this ecu be a direct plug in? or do I have to get a conversion harness?
        It would be a direct plug in, P06 is OBD1, so if your CB, but do not use the ecu as is!
          I don't see "f22" in that converter to list. You don't wanna put an Ecu in your car that is chipped and tuned for a D series engine or something other than an f22.
          P07 : 92-95 OBD-1 Civic VX
          P75 : 96-00 OBD-2 Integra LS/GS
          PR4 : 90-91 Integra LS/GS
          P05 : 92-95 OBD-1 Civic CX
          D and B series.
          98' Mustang 3V Swap
          11' VW CC R36
            Will it plug in? Yes. Will it just plug in and run your car? No.
            Think of a chipped ECU as a blank slate. You need to tune it, or it's worthless... or worse, harmful.
              Thanks, I knew it wouldnt run my car, but I just wanted to verify that It would plug into my factory harness, and it would be programmable to run my car. Should I buy a stock P06 and have someone chip it when I get my motor built. Or should I buy the one that has been chipped already with a zif socket in it?
              (Im so excited, Im pulling out my new motor tomorrow and dropping it off at the shop.. monday is my day off I can tear it down and start getting machine work done and spending cash on partz!)
                Yes yes.
                Sorry my post sounds like it won't work in the car. It'll work, but it needs to be tuned to operate the car. The way it is now, it won't run the car the way it is.
                98' Mustang 3V Swap
                11' VW CC R36
