Ok so ive been wondering if i run premium in my CB can i advance the timing a few deg. I know that alot of programmers for newer cars will advance timing on a 93 octane tune. So just wondering if i could do that on my CB and possibly see some small improvements. I don't drive the car much so im not worried about the extra cost.
Running Premium
you wont see any improvment other than the weight of your wallet.
even though ur timming is higher your compression ratio is still low. 91 needs alot more juice to ignite for a complete combustion.
How advanced are you?What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
Originally posted by accordztech View Postyou wont see any improvment other than the weight of your wallet.
How advanced are you?Looking for a CB7!
Originally posted by BoxMan View PostIm not yet i was just curious. I do plan on completely upgrading the ign system. My friend did a full MSD 6al setup on his 90 prelude Made a noticable difference in the car. So i plan on doing the same. Thats why i was wondering about advancing the timing
1) The OE ignition was in poor condition.
2) A placebo affect.
The OE ignition in good condition will be more than good enough to strongly ignite the fuel.
If your engine does not require higher octane fuel, then using higher octane fuel (i.e. petrol / gasoline) will typically result in a very slight decrease in performance (and economy). This is because higher octane fuel is typically slightly less energy dense than lower octane fuel (i.e. less BTUs per CC of fuel volume).
This is because many of the additives used (as a fairly large % of fuel volume) to increase the octane of (unleaded) fuel are less dense than the 'petrol' component of the fuel that they displace.
A higher compression engine makes more power than an otherwise identical but lower compression motor because of the higher compression ratio, not because of the higher octane fuel. In fact the higher compression engine makes more power despite the fuel being less energy rich, i.e. it is more efficient than a lower compression engine.
You may possibly make some (very slightly) more power by advancing the igntion slightly, but if so then IMO this would be because the ignition was not quite advanced enough to start with. This might not be that unusual because the stock timing is likely to have some margin for error, with a bit retarded being safer for the engine than too advanced.Regards from Oz,
John.
