I am having a h22a installed into my 93 ex and i was wondering should i get a seperate tach for my rpms since its a different engine? The only reason why I think I should get one is because I have the stock trans and its going to drop out of vtec everytime I shift. Would buying a rpm tach fix this problem?
Rpm tachometer!
Let's clear this up, are you going to rev higher than the stock tacho will show, and that's what will make hitting VTEC hard to do? If not there's no way any tacho, aftermarket or not, will help you stay in VTEC.
It's the transmission that dictates where you end up after a shift, if the gears are too tall you may end up below VTEC, but no tachometer will help, only another transmission.
Originally posted by afi2black View PostA solution I did is I got a Autometer Pro Shift Lite and installed it on the dash. It is wired to the coil, so that should be accurate if you feel the tach isn't.
Changing the tach won't actually affect performance, any more than getting a new fuel gauge will give you better gas mileage. The tach just tells you how high the engine is revving. The stock CB tach goes high enough to show a stock H22's full usable range. The only benefit to a new tach would be for accuracy reasons, as afi2black has mentioned.
