f22a1 turboing tips needed!
    i want to turbo my f22a1 motor running 14psi..... or i want to make 400hp not whp out of this i need some tips, parts needed, and where to get the parts at........someone help
    93 accord coupe lxr
    10 fusion se slammed
    idk much bout turboing an engine but I think you will get everything you need if u search bro there's couple or a lot of people with turbo's you might learn from them if u search and read.
    92 Accord Cb7 ^^
    My Ride Thread~~Click Below.
    http://www.cb7tuner.com/vbb/showthread.php?t=176232
      Holset hx35
      750cc injectors
      Walbro fuel pump
      Gm 3bar map sensor
      Crome
      Chipped p06
      3" exhaust
      Ebay special large fmic
      400hp(350whp) or bust
      Praise The Lowered...
        p06 ecu is for a honda civic
        93 accord coupe lxr
          It's from civic!!!!
          Originally posted by WiKKeDV16 View Post
          Holset hx35
          750cc injectors
          Walbro fuel pump
          Gm 3bar map sensor
          Crome
          Chipped p06
          3" exhaust
            just wondering are you thinking of running it as a dd? 400hp is alot.
              If you want 400hp f22 to be so call "reliable" you need to spend at least $4000-$5000 If you dont have that kind of money for full build and just want to bolt on huge ass snail to make 400hp, you might as well start looking for new motor to swap in, because it won't take to long till it blows.
                Well the OP said 400hp "not whp" so that translates to about 350whp which isn't that bad..300whp = easy 2 reach..350whp not too far off..
                Its do-able..just gotta be smart and take the right precautions..
                Racegas...meth injection..high flowing manifold(reduce egts) as comparted 2 a log manifold or similar..
                  all forged internals 800-900?
                  resleeve $900 ?
                  head work $1000
                  teh urbo 700-800?
                  engine management $1000
                  killer tune
                  ____
                    Originally posted by bcjammerx View Post
                    all forged internals 900.00
                    (Bisi rods 350.00)
                    (Cp 85.5mm 550)
                    Bisimoto cam/cam gear=400(I didn't look up prices)
                    Holse hx35(250.00)
                    Professional rebuild and balance(250.00)=500
                    Engine management=free
                    Chipped ecu=150
                    Wideband=250
                    Ostrich=175
                    Fuel delivery
                    Precision 1000cc =350
                    Walbro pump=120
                    Bosch inline=150
                    killer tune
                    Fixed.
                    Lol..
                      so what does that have to do with anything?
                      you asked for a list of what you need and that is exactly what you got
                        400hp on a stock block is going to be tricky. Doable, but the condition of the motor and the quality of the tune will determine how long it will last. It certainly won't last for very long...
                        And yes... if the P06 sounds weird to you, you have a LOT to learn before attempting a 400hp turbo setup...
                          how can u make a p06 ecu work on a f22a? and i have 8,000 to spend on this project so whatever i have to do to the engine and tuning it i think i have enough.... just want to know would the aem engine management system work instead of the p06 ecu?
                          93 accord coupe lxr
                            AEM would be expensive and honestly unnecessary considering the price of a chipped p06 or p28 (for vtec), and the FREE tuning software you can get for it.
                            And with your car not making much traction now, I'd be more worried about getting everything squared away at stock first, maybe some better quality drop springs than those you have and some good shocks.
                            EDIT: That is assuming you stick with a more mild goal around 250 whp, like we were discussing privately.
                            MRT(vvv) --Stock CB7 Enthusiast #1--
                            Vouches: new_beginnings, ThrakBarts, beanzfynest617, JaK FRoSTWhiTE, 92_EX_Ninja, mak
                            i am with the dumb. i cannot brain.
                              i prefer hondata for management. 400 is easy on a built block and sleeving is not nessassary for only 400hp just forged internals. bisi valve springs and a no headwork stock cam. turbo components are going to be what you need to concentrate on.
                              member ride thread
                              DIVULGE MOTORSPORTS
