Oil light briefly flashes when car starts
    When i get in my car to start it i turn the key to eccesorie and all the lights come on (battery, check engine, oil, etc) then i turn the key to start the car and the oil light quickly flashes once or twice emmidiately after starting (unlike everything else which shuts off after starting). I have plenty of oil in it but i was just wondering why its doing this. Thanks guys. 91 Lx f22a1.
    _____________________________________________
    2 year ASE Certification/Auto Technician Degree completed
    Sign of the oil pump taking a dump?
    98' Mustang 3V Swap
    11' VW CC R36
      not sure. Hope not. not sure how hard it is to put in a new oil pump...
        I read it COULD be the oil sensor sending unit could be going bad. But im not sure.
          the oil sensor is basically an on off switch. id say more likely the wiring. check the single wire that goes to it. happened to me once and when the engine would shake the wire was grounding out and making it flash.
          member ride thread
          DIVULGE MOTORSPORTS
            I don't know where it is...
              on the back of the block
              member ride thread
              DIVULGE MOTORSPORTS
                Ok, i'll go check out my manual to see exactly where it is. Is it a bitch to get to?
                  find your oil filter...it is directly above it
                  sounds like normal operation to me though
                  ____
                    It could be, ive just never noticed it before. When i start it its on for a brief second (as is the check engine, battery etc), then it shuts off real quick blips back on and stays off.. I do have an oil leak somewhere that ive had for atleast a year (ive owned it that long) but i don't know where. It uses about a quart a month or less depending on how far i drive. At first i thought it was just my dizzy oil seal, so i replaced that and it seemed like the oil didnt move for a good month, now its dripping down from around the dizzy again and getting all over my tranny (smell bad on the exhaust). But i think i have another leak somewhere else above my exhaust behind the engine...
                      happens to me when i run a non-oem filter and when im below the full line on the oil dip stick.
                      which sucks because i have to change my oil filter tomorrow and i only have half a quart of oil left tocompensate.
                        Well, i'll try adding oil so its right at or a hair above the full. As for oem filters, im not even sure what i use, but its not oem.
                          I would try the looking at the oil pressure sending unit before doing anything.
                            I have similar problem. Mine doesn't come back on though. just stays on for a second after a "cool" start. but not when i just shut it off.
                              I wouldnt worry about it if the light stays off once it goes off, and you dont hear any strange clickclackclunktaptickknock etc.
                              1989 cressida: Polycog diesel ultracharged, high tension muffler bearings, Manestically spaced pivot bearings, High definition halogen fluid, Flourescently scored bio-fuel seperator, flux capacitor and a Sega Genesis hooked up to a 9" b/w tv via cable to antenna converter.
