what is
    what is
    a ENGINE DAMPER KIT
    It's usually a stabilizer of some sort to limit engine movement. When you've got a powerful engine you will benefit from harder engine mount bushings and/or a stabilizer. It'll limit movement and help the engine settle quicker when you release the gas quickly from full throttle (eg. to shift when driving hard) and similar. It'll actually help you get power faster after shifts, but it also saves your exhaust manifold and exhaust by limiting sharp sudden movement that could cause cracks.
      It's basically a strut or shock absorber you put between your engine and firewall or other solid place in the bay. It stiffens with less harshness than harder mounts, giving you a little more power transfer to the wheels.
      *edit* slipped in before me.
