Originally posted by mcdizzle
View Post
supercharger
OLD
my bad i suppose...i'm used to working on rwd v-6 and v-8
... it's always been the rule of thumb for me to rebuild and refresh all engine parts before any boost is applied... keeps the always there "weak link" from rearing it's ugly head and causing expensive or extensive engine damage... let alone the expensive new goodies...
THOU SHALT NOT SHIT IN DEEVE'S WHEATIES
you can go on youtube and see several cb7s with superchargers on them....they scream.....UPDATE: I just looked on there to post a link and now I can't find one video......will keep lookingLast edited by Sway; 04-16-2009, 03:50 PM.
Originally posted by cb7_07 View Postturbo=lagging
supercharge=overheat
lolhttp://www.cb7tuner.com/vbb/showthread.php?t=138029 <-mrt
diy whore riiittteeee here
[URL="http://www.cb7tuner.com/vbb/showthread.php?p=2208455"]
http://www.b20vtec.com/forums/members/pr3pg4lyfe.html
Originally posted by bigbadnothing85 View Posti concurr with fneg... lower compression is a must.... and above all else... REDO YOUR HEAD!!! putting boost through a stock head and cam is MUY MUY BAAAAAAAAAAAAAAAAAAAD JU JU!!!!
Originally posted by J3wman View Postlook for superchargers for an F22A1 (assuming thats what you got) thats the engine code for our cars. but the benifits of a turbo is you get more power but only in the upper revs other than that it creates turbo lag this is because it uses your exhaust pressure to spool the turbine in the intake and create more pressure in the cylenders. The supercharger however uses a pulley system to create this effect, it gives you power through out all your revs but also gives you slightly less power. if youre a mad man do both however do remember for forced intake youre gonna need high comp pistons and rods.
lol
And not all turbos lag considerably. It's all in the design.
There are no supercharger kits available for the CB7.
There are very few turbo kits available as well.
If you want to go either route, you need to build your own (even if you find a kit, it's best to do it yourself anyway!)
There will be a supercharged CB7 on this forum soon enough... unlike any you've ever seen.
