supercharger
    supercharger
    does any one know if they make a supercharger for the cb7 or can you only get turbo and what are the benifits and flaws to each one
    not sure about the supercharger for a cb... but... the turbo will have a slight lag in power till the exhaust pressure builds to spool up the turbo, and the supercharger, while not having the lag because it is belt driven... on the same note... the supercharger kind of robs the power it creates BECASUE it is belt driven, which also means its more of a fight to spin the screws inside the supercharger to create and maintain the pressure needed for boost... they both have their ups and downs... but i think if you have a cb with a 4banger go turbo
    THOU SHALT NOT SHIT IN DEEVE'S WHEATIES
      super charger won't fit..but don't quote me on that.
      just get turbo.
      Yes my name is Dang, Don't use in vain
      1992 Honda Accord EX (Coupe/Bordeaux/Auto)
      1992 Honda Accord EX (Coupe/Bordeaux/H22A MT)
      2008 Honda Accord EXL (Coupe/SanMarino/6spd)
        you could fabricate one on there.
        take runners from the f22 and weld a supercharger to them.
          just get turbo.
          im pretty sure there is enough room for a supercharger. they make them for eg6(i think) if they can fit in there then a supercharger will fit in the accord engine bay.
            Someone on cl was selling a h22 sc, so i'm sure they make one..
            http://www.cb7tuner.com/vbb/showthread.php?t=188155
            Bought from: ChampCoupe
            Sold to:Losiracer2
              Maple50175 - you're annoying =P
              Brandoncb7 - I don't mean to come across like an ass but I see why you irritate Aaron now.
              JoshM - Crotch rocket = chick magnet.
                Originally posted by slick View Post
                I want it!
                i want to supercharge real bad.
                  this will be the best way to do it in my opinion. i was thinking about doing this for a while. super charging by using a ati procharger the only thing that will have to really be modified is a bracket to mount it to other than than it is pretty strait forward her is one for sale he had it an a fully build b18c1 at 10 psi it made 300 whp and 240ish wtq so i would thik it would make 250 on a f22 and with a pulley change it can make more boost probley netting 300ish whp.
                    and then after a couple of runs, u'll see massive amounts of smoke coming from under the hood.
                    Project M3 - http://www.cb7tuner.com/vbb/showthread.php?t=157903
                    -(B-Pillar Bar Originator)-
                      look for superchargers for an F22A1 (assuming thats what you got) thats the engine code for our cars. but the benifits of a turbo is you get more power but only in the upper revs other than that it creates turbo lag this is because it uses your exhaust pressure to spool the turbine in the intake and create more pressure in the cylenders. The supercharger however uses a pulley system to create this effect, it gives you power through out all your revs but also gives you slightly less power. if youre a mad man do both however do remember for forced intake youre gonna need high comp pistons and rods.
                      They rise their wooden pints and they yoik and sing
                      And they fight and dance 'till the morning
                      Dont forget my MRT for my 1992 Honda Accord LX
                      Everything in Japan is made with carbon fiber and used panties.
                        that will cause a big boom you will want low comp for a force feed motor
                          i concurr with fneg... lower compression is a must.... and above all else... REDO YOUR HEAD!!! putting boost through a stock head and cam is MUY MUY BAAAAAAAAAAAAAAAAAAAD JU JU!!!!
                            i love all the horrible horrible information thats being construed in this thread....
                            My Members Ride Thread
                            You have to think outside the box to get IN the box!
                              hahaha, you cant be serious...
                              Sold to:Losiracer2
