bad tranny
    bad tranny
    ok how hard is it to drop and swap a transmissionon a f22 anyone had to do it please
    it is easy just when you do it you should do the clutch,throwout bearing, and resurface the flywheel or replace. to while you are there. if you are good with cars 3 hours if you are learning give yourself 4-6 hours.
      yeah i got a new stage 1 cluth and planned on gettin a new flywheel and throwout bearing.. thanks
        check torque specs to it is critical
          ive done hella FWD and i cant even do one in 3 hours. it took me 6 hours to fully pull an entire 5 speed conversion.
          this is without air though.
