Is it possible?
    Is it possible?
    Could I get 4 doors off of a lx and put them on ym DX so I can have power locks and windows? Is there a DIY on it and would they work? (btw iv looked and the wiring is there its just tucked behind the door frame)
    -Will
    I'm sure you'd need the other associated wiring, like the relays and such, that aren't located in the doors.
      Well the wiring is there to connect to but I dont think there connected to anything but the battery considering the multimeter comes up false on most of the connections.
      -Will
        Pretty sure you would need the window regulators, door panels and switches, and the full wiring harness. I wouldn't put the whole door on, just swap components. My friend put factory power windows in his truck. He had to do quite a bit of disasembly to the donor car to get all the wiring out. I assume you'd have to do the same.
        http://www.cb7tuner.com/vbb/showthre...=1#post1823428
        My Custom BB6 Dash Swap Thread
          Sounds like something worth trying! Good luck with it!
          My 2004 Subaru Impreza WRX Thread
            i think honda wires all cars for it but you will need to add the fuses(the reson your meter doesn't work) and relays to the fuse block under the dash for them to work an like said above i wouldn't change out the whole door just the guts and panels and it should work.
