Turbo or H22 Swap?
    Originally posted by turbo90accord View Post
    I dont understand why everyone allways throws the reliability card out when turbos are mentioned. Other than tuning the car once there should be no reliability problems unless boost is abused. no different from an h22 that gets railed on daily eventually something is going to fail its all in the driver not so much the setup. I personally have been turbo for almost 5 years now and have had no issues with reliability.
    Turbo CAN cause wear faster, because turbos tend to produce more heat. Especially a budget turbo setup, since people often use smaller turbos.
    Additionally, I'll rev my H22 up to 7500 MAYBE once a day... Some may redline it at every stoplight, but not everyone.
    A turbo setup, especially one with a small turbo, will see boost under normal driving conditions.
    An H22 swap requires a P13 ECU. No more.
    A turbo setup requires a custom tune. The reliability of the system depends largely on the skill of the tuner, as well as the condition of the motor and the quality of the components used.
    Can turbo be reliable? Certainly. Moreso when installed and used by someone that truly knows what they're doing.
    An H22 swap is more of a "do it and forget it" deal. It's a stock motor. The only thing you have to remember is to run premium fuel!
    That being said, turbo is the cheapest way to make the most power. You'll spend far more time than money learning, tuning, and maintaining a turbo car.
      I would lean toward the FI set-up...but it has been said, you can't skimp.
      Buying a junkyard turbo with 80k on it and bolting it up is asking for problems.
      Your set-up is only going to be as strong as the weakest link, whether that's the turbo, the conrods, the fuel system, the clutch... It seems like there's a crap load of information on this site to help you determine what those weak links are so you can address those issues as you start putting things together. Also, just because the oil has been changed regularly and the car seems to run strong doesn't mean that it's completely capable of handling the added stress of positive manifold pressure. There are plenty of other test methods out there (compression, leak-down, etc.) that will give you an idea of what you have to work with before you even get started.
      The ignition side of things should get some attention as well, you gotta be able to light the fire.
      I would also test and/or replace anything to do with the fuel system (pump, injectors, etc.) since these parts are the ones most likely to ruin the party once it gets started.
        Originally posted by cb7addict View Post
        IMO turbo is more fun than vtec and the cb I rode in was at 5psi and felt like it pulled harder than my BB6.
        lol i think philip likes how my motor pulls but anyway i say boost i love it just dont drive like a mad man and beat up the motor and you will be fine
          Prob should have went into more detail. No compression problems. I know that the weakest like will most likely be the stock clutch which just feels like a weak link in general. I planned on replacing that anyway. If the motor goes it goes just means its time for a swap lol. Now if only someone would total my element and the motor on the accord could go at or around the same time that would be nice lol. Id love to swap a K24 in and turbo that.
          But for now it seems a turbo will be the way to go. I have a DD so im not worried about the car being tied up. Just gotta get some minor things fixed first. Mainly cosmetics and a clutch.
          Looking for a CB7!
            The clutch is an absolute MUST. I don't even look at that as a replacemnt... I look at it as part of the turbo setup.
            I always say that boosting your DD is a bad idea... because of the added complications that can arise from 1) boosting an old car, and 2) adding so many things that could potentially go wrong. Since it's not your DD, turbo definitely seems like the right choice.
              Thats what im thinking. They dont call me boxman for nothing lol Heres my DD
              Looking for a CB7!
                i love to here the turbo spool & the blow off valve when shifting. i have an h22 n my cb & it's a BBIIGGGG difference n how the car drives now. i'd like to turbo it but i think i'm gonna get a bike instead.
                http://www.cardomain.com/ride/3222203/5
                  i suggest boost... but then again, i am a turbo junky.
                  Originally posted by Soichiro Honda, Honda Motor Company Ltd. Founder
                  Action without philosophy is a lethal weapon; philosophy without action is worthless.
                  No, I don't own a CB7, but I do own a F22A6 and a B16A trans. All going in a 90 integra sedan .
