h23 tranny?
    h23 tranny?
    differential bearings are they hard to replace? and how much are they? the reason i ask is because this guy has one for sale by me. thanks in advance
    diff bearings are about 40 bucks each. you will probably need both axle seals as well.
    to get to the differential, you'll need to pull the transmission apart and both shafts need to come out in order to access the differential.
    if you know what you're doing, it may take you around 4-5 hours.
    I <3 G60.
      thanks depending on how much this guy wants for the trans would it be worth it to take to a shop as i never took one apart before
        shop will probably charge you around 300-400 bucks. if that's the case, you may be better off buying a low mileage LSD h22.
        I <3 G60.
          ok thanks thats the answer i was looking for thanks alot for the fast ass responses
            if you have never done it before then have a shop do it and most shops will not use parts that you bring in and if they do they will not warrenty it
              so this guy said he want like 200 obo for the tranny should i pass? keep in mind it has bad differential bearings. what do you guys think
                id give him 100. you dont know condition of synchros or gears.
                I <3 G60.
