So i just installed a oil pressure gauge in my car and wanted to confirm that these readings are ok. I have no idea what they should be at so here it goes
engine: H22A
oil: Royal Purple 10w-30
Filter: NAPA
Idle when warm: 16psi
2500rpm (warm): 60psi
vtec: 92psi
the pressure also does this weird thing when accelerating to around 4k. The psi will rise to 90psi then dive to 82psi and continue climbing. Is this due to that valve in the oil filter? Also the gauge is mechanical and im using the plastic tubing that it came with. Is this able to hold up to this kind of pressure? I assume it is because the gauge goes from 0 to 100 but i would like more information on this.
engine: H22A
Filter: NAPA
vtec: 92psi
