Short Ram Intake or Cold Air Intake
    hey i live in florida and it rains a lot so im plannig to get one of this but i don know wich one is better!!!!! Plz need help????
    http://www.cb7tuner.com/vbb/showthread.php?t=19272
    http://www.cb7tuner.com/vbb/showthread.php?t=120560
      thanks but i want to know whicohne is better cuz down here rains almost everyday!!!
        If you read the two threads I posted, you'll find your answer.
          oohhhh ok i found it... thank u!!!!
            just do a short ram if you're living in an area where it rains a lot. even if you put one of AEM's bypass valves on, i don't know if I would trust it entirely to stop all water.
              yeah everbody tell me the same thing!! n i found one on ebay for $10!!!!! n just want to bling my motor!!!!
                Spray paint it black.
                  short ram is better for bottem end
                  Cai is better for top end
                  i switch back an forth everyday, i love the cai
                  UNDERGROUND SOCIETY
                  NEW COUPE MEMBERS RIDE THREAD COMMING SOON
                    Short Ram +1....Just buy A EBAY kit and change the filter!!!
                    1990 Accord LX Sedan~Sold
                    1993 Accord EX Sedan~Sold
                    1995 Suzuki GSX-R 750~Totaled
                      i hear this everytime i tell some1 i run a ture c.a.i. it doesnt "suck up" water for two reasons. 1 the filter is relocated to inside of the front bumper, and has what i call, a plastic "splash guard" covering in between it and the ground. 2 i went to outerwears (www.outerwears.com) and had a custom "pre filter" (which is water repellent) made for my k&n. i tested it by spraying water on it and it just beads up and runs down, similar to what rain-x does on a windsheild. now keep in mind you dont ever want to submerge the filter, like trying to drive through a deep puddle, but with the pre filter ive never had a problem, even driving thru a puddle at 40mph the filter has never sucked up any water.
                      a short ram intake doesnt do any good. its just a 3in pipe with an aftermarket cone filter on the end of it located in a hot engine bay. if you notice, a stock airbox has the stock filter contained, so it does not suck hot engine air into the intake. well the short rams are not contained, therefore they suck in hot engine air, regardless of the temp outside.
                      as anyone would now cold air produces a better charge which ends up to be a little more power.
                      a bypass valve was designed for if the filter is completely submerged under water, which if happens to you then you shouldnt even be driving a car, it puts a break in the intake piping so that it wont guzzle water into the intake mani. good design to scheme money if you ask me. and as far as a bypass valve is concerend on a TRUE c.a.i. it defeats the purpose of the cold air, bcuz your sucking hot engine air through that filter when the enginge is running. POINTLESS.
                      c.a.i. is the way to go, even if you live where it rains a lot.
                      I LOVE My CB7
                        you live in tx you should know better
                        CAI WILL suck up water if you hit a big puddle...and in tx...that's almost anywhere I've hit several such puddles all the time...course I live out in the kuntree
                        BUT usually it is folks that have them right by the ground that have issues...my issue with cai placing is that unless your fender liner is pristine you will get kick up from the tires...that is a LOT of shit. Fender liners are always shit dirty cause of road dirt. Your filter goes to shit quick
                        That is my only real gripe with cai...well that and it's a misnomer.
                        ____
                          Cai is better for top end...
                          You took the words right out my mouth.
                          1990 CB7 - Almost Done - Delta 272, SRI, 2.25 catback, Bisi intake manifold gasket, A6 intake double stacked, H22 plenum, AEM cam gear, F23a block, F22a head, Wiseco K20 pistons, DSM 450cc injectors
                          2004 Z33 - Brembo BBK, Nismo spoiler, Nismo lip, Nismo shift knob, AEM CAI
                            it is night an day
                            UNDERGROUND SOCIETY
                              my car pulls alot harder with the CAI, even though the SRI is just as good. it tends to ........................ out in the topend.
                              UNDERGROUND SOCIETY
