window track adjustment
    Is there any way to adjust the window in the track at all? I took off the cover, and i cant really see anything. I tightened all the screws on that cover since they hold the seal down, but the problem i have is that it pushes the back part up farther than the front, so that i have to push it down continually while it's being rolled up so that it doesnt push out of the back corner when it rolls up.
    So what do i do about this?
    Cars:
    91 Accord LX Sedan (sold)
    98 Accord LX Sedan
    95 Eagle Talon TSI AWD (E3 16G, PTE 780cc, Godspeed FMIC)
    if your talking about the window coming out of track like i think you are then you can take the door panel off and the window has 2 10mm bolts that hold it to the window regulator. loosen those bolts and push the window as far back as possible then retighten. if that doesnt work then you need a new window regulator
    USDM as F$CK
